Is ther anyway to turn off the the now playing section off when broadcasting? i have played a couple of sets on an internet radio station, winamp listeners can see the now playing and what playing, but when i finished broadcasting and turn it off, it still displays me on thier winamp, is there anyway to turn it off!!??
geposted Thu 23 Aug 07 @ 7:23 pm
yes ,
this is possible in two ways
one simply with dj cels registry tool for pro users only
the second is a by hand registry modification
only do the following if you understand registry editing , and make this change exactly or you could cause pc issues
go to run and type "reg edit"
search for virtual dj
look for the key broadcastsongtiles right click on it and press edit , change the value from 1 to zero
hope to see you as a pro user soon :)
geposted Thu 23 Aug 07 @ 7:29 pm
"only do the following if you understand registry editing , and make this change exactly or you could cause pc issues
go to run and type "reg edit" <<<<<<<<<<<<<<<-------------DIDN'T WORK
look for the key broadcastsongtiles right click on it and press edit , change the value from 1 to zero"
the Dj cels registry tool-can ue a bit more clearer on that please.
geposted Fri 24 Aug 07 @ 9:08 pm
remove the space sorry regedit
geposted Fri 24 Aug 07 @ 9:49 pm
geposted Thu 30 Aug 07 @ 4:32 pm
Sorry, as stated it only for pro users only.
geposted Thu 30 Aug 07 @ 4:34 pm
Thanx mate, that worked with the reg edit, took a while to find it in the registry, but got there in the end.
geposted Fri 31 Aug 07 @ 10:16 pm
not to worry, that worked fine with the regedit. Thanks.
geposted Thu 20 Sep 07 @ 6:59 pm
