help! djing right now, but when I search for asong mpg files just show up as normal songs and video doesn't play unless I go to the folder the song is in. what can I do to fix it asap as it takes too long to find the video in the folder! cheers
geposted Thu 23 Aug 07 @ 10:18 pm
If your directory structure is not to deep with tracks - right click and do a Recurse on the directory. Do in smaller chunks if necessary. - try that?
geposted Thu 23 Aug 07 @ 10:28 pm
hum.. weird
What happens if you got to the folder with the mpegs, and right click that folder and choose "add to search database"
do they work better then ?
geposted Thu 23 Aug 07 @ 10:29 pm
also how do I get global database back? I keep clicking at the top which is desktop and that's no good for a search.
thanks
thanks
if your running version 5
make a filter
Filter: type=video
hopefully that helps
or
name: top 20 video
filter: top 20 nbplay and type=video
***edit: sorry i misread ****
make a filter
Filter: type=video
or
name: top 20 video
geposted Thu 23 Aug 07 @ 10:30 pm
Create a Filter folder - (call it Local Database if you want)
Use a filter of :: isscanned=1 or isscanned=0
This will show you all your files.
geposted Thu 23 Aug 07 @ 10:31 pm
it also keeps saying sorting when I type and the whole thing locks up. its getting busy now so going to have to make the most of it. will figure it out tomorrow. thanks.
geposted Thu 23 Aug 07 @ 10:34 pm
This karaoke/video bug with search has already been reported to the Dev Team.
geposted Thu 23 Aug 07 @ 10:44 pm
