Hi Guys,
I installed VDJ 5, and it installed as the instructions stated. For some reason on first boot up it shows my music drive as corrupt and wants to fix it, and I have lost my cue points. After I do the "Fix" as descrbed the music drive is ok, but my cue points are still missing. When I shut down and reboot, the same error shows up on the music drive. Iam running a tower with M-Audio 44 harware. There is no USB cable. Version 4.5 worked fine. Any Ideas?
Thanks
Chris
Thanks
Chris
geposted Thu 23 Aug 07 @ 11:53 pm
Chris I'm having the same issues although from my thinking its due to the new browser Atomix implemented since it doesn't read the DB the same way. All we can hope for is a fix in a later version unless we're stuck having to restart fixing the cues, CBGs and bpms.
geposted Fri 24 Aug 07 @ 12:25 am
Try this please --
Do a CLEAN, CLEAR, and FIX on the music drive. What happens now?
Also, do you have iTunes installed? And are all of those tracks in you iTunes DB?
If so, go to your iTunes folder in MyDocuments\\MyMusic\\ and rename the .itl and .xml files so VDJ doesn't see them.
Then do the whole process over, what is the outcome?
geposted Fri 24 Aug 07 @ 2:02 am
