HI,
When I disable the autogain, the small gain knob is adjusting for each new song that is played in each deck. Is this suppose to do that?
Also I am using the skin multifunctions 1.5. The sliders are placed in the red. I bring them back down out of the red. How do i save this setting? When I close the program and reopen...the sliders are back in the red zone.
geposted Fri 24 Aug 07 @ 2:31 am
its a skin feature/issue ... The skinmaker has choosen the button to show real gain i guess
default skin does not move gain knob if auto gain is disabled
geposted Fri 24 Aug 07 @ 2:33 am
Not true. i went back to the virtual DJ Video skin and the small volume knob moved when the auto gain was disabled.
geposted Fri 24 Aug 07 @ 3:09 am
The knob might move but it is showing you the analyzed volume level with respect to 0.0dB
Test this way -- (I used the MixLab skin since it has the reading separate from the knob area)
Set the AutoGain to Always 0dB - load a track -- read out is 0.0dB
Change the AutoGain to Disabled - load same track on other deck -- read out is either + / - 0.0dB based on what VDJ sees.
geposted Fri 24 Aug 07 @ 3:35 am
