Forum: VirtualDJ Skins
Topic: Key Changer
I don't know if what I'm going to ask is possible but I'll ask the question anyway!!
Is it possible for anyone to put a key changer on the main skin of the default virtual dj skin(The video Skin) that you can step down and up a bit like the way the pitch changer is where you have a slider with the key - and key + is indicated.
It would be even better if after the karaoke track is finished the key changer re-sets to normal key so you don't forget to re-set it yourself manually.
I am new to virtual dj and if I could do this myself I would do, but I don't really understand how to do it, so if there is anybody out there that could help me out it would be much appriciated.
Many thanks
Billy24
geposted Fri 24 Aug 07 @ 11:31 am
You need to use "key_offset".
Open the xml of the default skin, and look for the "##pitch" text. There you will see how to set a slider for pitch. Then do the same with "key_offset". And there you go.
