It wasnt happening yesterday but for some reason my friend's set started acting weird when i went over to his house to mess around w/ his TCV set up... whenever we had a track on and TTs were on full control... when we stopped the turntable the VDJ would pick up as if the vinyls were spinning veryy slowlyyy... and make the track audible.... verry annoying we couldnt figure out what was going on... any suggestions on this?
system specs
mk2
TT500s
dn-x300
vd 4.3
thanks in advanced
system specs
mk2
TT500s
dn-x300
vd 4.3
thanks in advanced
geposted Fri 24 Aug 07 @ 5:36 pm
ground your turntables to the PC
And if needed, adjust the silence slider until there is no interfearance when the timecode is not spinning
(look at the waveform in timecode settings, it should be still)
geposted Fri 24 Aug 07 @ 6:54 pm
i got you... well the TTs are grounded to my dn-x300 but ill try to ground them somewhere else... and ill check the waveforms when i get home... thanks
geposted Sat 25 Aug 07 @ 12:46 am
How do you have your TCV connected?
like where are you connecting them too?
what do you have your TCV selected on?(relative, absolute, smart)?
do you have another soundcard besides the hercules?
geposted Sun 26 Aug 07 @ 10:17 pm
are you using the included v3 or the latest pro demo?
geposted Sun 26 Aug 07 @ 10:36 pm
