Does anyone know if i hook up to cd players to the console if it can work with the VDJTime code cd. cause i see a setting where you can change it to the VDJTime control.
geposted Sat 25 Aug 07 @ 7:34 am
yes it will work , for a duration of 5 minutes at a time in home edition
for full use you must upgrade to pro
at a discount
check out the pro demo :)
on the timecoded preferences
you will see Vinyl or Cd choose the cd option
at a discount
geposted Sat 25 Aug 07 @ 12:08 pm
Thank alot am gooing to have fun now. So you say that in pro version you can use it longer than home version.
geposted Sat 25 Aug 07 @ 10:56 pm
yes the timecode engine in the home edition is a demo so you can see its potential.
the pro version has a much improved newer engine aslo featuring a new technology called clear sound
which when enabled greatly increases the quality of stratching and other actions
geposted Sat 25 Aug 07 @ 11:40 pm
it does work
geposted Sun 26 Aug 07 @ 8:28 pm
