Well the first problem is that you own a Packard Bell --- love it - not! Just joking...
Hey, sounds like you had a gremlin there. Little power flux or something. Just keep chugging away. It sounds like your data is still fine. Also, is your data on an external drive? And what brand of drive is it? You might have just hit a spin down or spin up cycle that got a bad read.
Let me know?
cstoll
Let me know?
cstoll
geposted Tue 28 Aug 07 @ 5:45 pm
hi cstoll
thanks for getting back, noticed earlier you were on down time, coffee break maybes or lunch (lazy sod) so popped out, anyway external is a 400gb freecom with 278gb free space, just gone back onto lappy after leaving it running while out and has come up with a "runtime errorr 6016, not enough space for thread data", does that help with your prognosis doctor...thanks
Tayla
Tayla
geposted Tue 28 Aug 07 @ 6:34 pm
Sound like your visit to the computer repair doctor didn't repair everything.
I will ask the DevTeam if it is significant to them. Maybe they can comment.
geposted Tue 28 Aug 07 @ 10:48 pm
Did you disable the ID3Tags reading in the config : "Never Read" ? What do you have : "Read ASAP" ?
Same question for "Search Database" : "Add manually" or "Add automatically" ?
How much RAM do you have (in Megabyte please: MB) ?
geposted Tue 28 Aug 07 @ 11:59 pm
@ djcel
thanks fellas for taking your time to help out, sorry for the delay...
tags - read on load
search database - add automatically
processor amd turion 64 x 2, tl-50 1.60ghz
ram 895mb
system type 32-bit
Tayla
tags - read on load
ram 895mb
system type 32-bit
Tayla
geposted Wed 29 Aug 07 @ 8:18 pm
