Topic: Multiple drives w/ identical libraries
Say I have 2 xternals hooked up to my laptop (one is the gig drive, other backup)..
I want to add 10 new files to each drive...I do that..
Do I need analyze the files on each drive separately? Right now, I'm seeing that....
geposted Sat 25 Aug 07 @ 5:35 pm
Yes, the data is stored independently on the drives now.
pages 3 & 4 of the Updates Guide - https://virtualdj.com/support/VDJ5-UserGuide_for_Updates.pdf
However; since you would be doing this on downtime and not at a gig... you could just copy the DB of Drive 1 to Drive 2 after the analysis... try that... but remember Drive 2 needs to be identical in files and structure to the Drive 1. Give that a try... should work.
Backup and save any already existing DB on Drive 2 just in case it doesn't work.
