Sometimes the tunes will go into the sidelist after they are put on a deck.
Anyone else have this happen and possible solutions?
Also have a few tunes that won't play. Did a check and everything seemed to be correct.
Reanalyzed sometimes worked, and sometimes not. After shutting down VDJ and restarting
a few times the song played . Anyone else??
geposted Sat 25 Aug 07 @ 5:37 pm
The songs will go into th side list for me if I deside that I dont want to play that song at that time and add a new song. I believe that this is in the user manual in the link above.
geposted Sat 25 Aug 07 @ 8:16 pm
Already have it disabled. After rebooting 3 times it seems to have gone away.
unfortunately I still have a problem with songs not playing.
They load and appear as if they are playing, but no sound.
If I shut down VDJ and open again it will then work.
geposted Sat 25 Aug 07 @ 8:34 pm
bogart - with all the very weird issues you keep posting it sound like you have bigger issues than VDJ. Sounds like you need to start looking at pulling some heavy maintenance on your system even to the extent of a fresh O/S load.
geposted Sat 25 Aug 07 @ 8:39 pm
i agree sounds , like you have a curupt os or , conflicting hardware in your machine , or if its getting to hot which can cause seriously odd things to happen
it may aslo be your powersuply if its a desktop as small fluctiations in power can cause freezes.
for starters , Check the irqs on your machine
http://www.helpwithpcs.com/upgrading/change-irq-settings.html
geposted Sat 25 Aug 07 @ 11:47 pm
This is a brand new laptop. Toshiba Satelite A135. Dual core intel processor T2080. It has Vista and the only other pgms I added was VDJ and winamp.
skyfxl
I will have to try your suggestion, however I am not technically savvy. But will give it a try
Thanks
PS SKyfxl: just tried that site and got page not found error. Went to homepage but did not see anything about IRQ.
geposted Sun 26 Aug 07 @ 2:14 pm
This is the correct link :-
Sky had added an 'l' to 'htm'
geposted Sun 26 Aug 07 @ 2:31 pm
even new laptops can come with irq issues , dell for example are major offenders
have you removed all the free crap programs they bundled with it these can waste alot of space and resources
geposted Sun 26 Aug 07 @ 5:52 pm
\I am trying to find out which ones are the bundled ones. Toshiba can't tell me.
ALmost tempted to uninstall vista and put on XP. But Vista seems to be ok.
geposted Sun 26 Aug 07 @ 6:52 pm
my tosh came with , network manager, bluetooh manager , powermanager , media manager , startmanager , wirelessmanager , dsl manager
and Network doctor which all turned out to be pretty useless :)
geposted Sun 26 Aug 07 @ 9:30 pm
