They show up in MM but not VDJ, the keys are showing up in VDJ though.... Any ideas?
geposted Sat 25 Aug 07 @ 9:09 pm
Yeah, VDJ isn't reading them. Heck my itunes ain't even reading them. But if I scan with the old mixmeister, they show up. I'm getting tired. I'm editing more than i'm playing.
geposted Sat 25 Aug 07 @ 9:51 pm
that not true, I use this as well, if you set your settings to "read ASAP" it should read them. The other thing is that you will need to click on all your folders to setup the database, if not when you do a search you will not find some music
geposted Sun 26 Aug 07 @ 11:34 pm
Please understand that VirtualDJ stores the tag information in it's own database. So, if you add a file to the database and then at a later date update the tag information (external of VirtualDJ, like using MixMeister or Tag&Rename) then you need to update VirtualDJ's database with the new information. This can be done by a couple of options -
1. Turn on the Tags option to Read ASAP as mentioned above, then do a recurse on the folders that have the updated files.
2. Turn on the Tags option to Read on Load, then when you go to play the track the info should be read.
3. Manually go to each file and use the FileInfo to import the new information in.
And, I am sure there are few other ways that I am missing because there are several possibilities depending on what got updated externally.
Hope that helps.
cstoll
Hope that helps.
cstoll
geposted Sun 26 Aug 07 @ 11:47 pm
Van Wilder wrote :
Mixmeister BPM's not showing up. They show up in MM but not VDJ, the keys are showing up in VDJ though.... Any ideas?
Because Mixmaister doesn't store TBPM key (number of beats per minute) into MP3 tag, but only TKey (initial key) and POPM key (popularimeter) with default value 3.
geposted Mon 27 Aug 07 @ 2:11 pm
Ok, Now that makes sense. It explains a lot. Where did you get this information?
geposted Mon 27 Aug 07 @ 4:51 pm
I load demo version MixMeister Studio Version 7.0.8.0 down.
bpm is shown in virtual dj
geposted Mon 27 Aug 07 @ 5:23 pm
You can try browse ID3v2 extended frames with any editor ( http://www.volny.cz/media-tagger/eng/index.html - best freeware ID3 tag editor which is working without instalation). After Mixmeister scan there are only new Key values, no BPM .
geposted Mon 27 Aug 07 @ 5:33 pm
@ Ludek I can't view the link, it's blocked a s pornography. So is there a reason why they made it that way, I mean the old mixmeister used to write the BPM's to the tags. What's your work around?
geposted Mon 27 Aug 07 @ 5:57 pm
hmmmm, you have any bad blocking filter... :-) Try this link:
http://www.viktorin.cz/media_tagger/eng/index.html
geposted Mon 27 Aug 07 @ 6:33 pm
That's just bad info, Mixmeister does store the TBPM to the mp3 tag.
geposted Tue 28 Aug 07 @ 4:10 am
Before Mixmeister scan:
After Mixmeister scan:
Where is TBPM? Tested with Mixmeister 6.1.3.0 and 7.0.8. Both with default settings and with the same results.
geposted Tue 28 Aug 07 @ 3:43 pm
I believe Ludek is right cause after a mixmeister scan, for me it doesn't show the BPM's in iTunes, VirtualDJ or even ScratchLIVE. It just does it for itself.
@ xgl_dj. If it does store them, where does it store them?
geposted Tue 28 Aug 07 @ 4:23 pm
Ok Sorry, my mistake, I thought you guys were talking about MixMeister BPM Analyzer but you guys are referring to Mixmeister 6.1.3.0 and 7.0.8.
geposted Tue 28 Aug 07 @ 9:06 pm
