Forum: VirtualDJ Skins
Topic: Newline or line break in TEXTZONE
When I was fooling around with some of the older versions of Version 4, I developed a skin that made extensive use of the newline character (\n) in some of the textzones--for example, I had a cue list that showed the first 6 cues in a song, and it made that list using newlines. The benefit of this was that I could add a text2 parameter and have all 6 items in the list switch between time elapsed and time spent at once, affecting all 6 lines. Now, VirtualDJ (later versions of 4 and version 5 now) seem to ignore the newline character--what's up with that? I tried switching the skin to CRLF combo (\r\n), I tried CR (\r) just in case, I even tried <br> tags--nothing works. Anybody got more information on this?
Now with the question out of the way, for my thoughts on the matter...
Now I've already converted the skin into using 6 different textzones where it used to use 1 (which I'm sure adversely affects performance, but not noticeably)--times 3 columns, times 2 decks. This means now instead of 6 textzones, I've got 36. And if you cound the 2 I was using for elapsed/remaining time, that adds another 4 where I used to have 2. Other than the obvious simplicity the ability to include CR generates, the fact that I could instantly switch whole columns of information back and forth between two formats or whatnot was very helpful. If we're not going to be able to use CR or CRLF in the textzones, it would be helpful if you could link textzones together into groups so that a click on one affected the text/text2/text3 etc. on the whole group.
geposted Sun 26 Aug 07 @ 11:38 pm
