Does anyone know how to change the 24 hour clock from Military time to US 12 hour standard time ??
geposted Mon 27 Aug 07 @ 4:48 am
It's always been a 24hr clock and is not able to be changed. If you want to have the 0-12 hours to show during the evening - just set the computers clock back 12 hours.
This is also good for getting the History play list to generate one with the date of the gig and not the date the gig ended if you go past midnight.
geposted Mon 27 Aug 07 @ 1:25 pm
If I do the 12hrs back.....What happens if you go past 12 midnight in the same day?
geposted Mon 27 Aug 07 @ 2:46 pm
Yes your display will show the 24hr equivalent of 1pm [13:00] , 2 pm [14:00], and so on...
geposted Mon 27 Aug 07 @ 3:03 pm
it should be..... check if you want 24hr clock or check if you want 12hr clock. maybe next time!
geposted Wed 29 Aug 07 @ 8:09 pm
