I'd like to see a playlist editor window that can be used while i'm playing. I have old playlists that have entries that are no longer there which will mess up VDJ. My old ADJ Pro_mix automatically removed and verified playlists when the were opened each time and vdj should do this also
geposted Mon 27 Aug 07 @ 6:56 pm
something that will verify filepath "if it still exists",
eliminates duplicate enteries of the exacts same file that has been moved/removed from where it was.
nice idea, I'd use it :)
geposted Mon 27 Aug 07 @ 7:47 pm
If you keep your database clean using the Clean and Clear options in the Config->Browser tab. Then when you view a playlist, the center panel will show files as not analyzed if they are missing from the database or find a match in the database. That is a quick flag for something is wrong -- again if you keep your database up-to-date.
geposted Mon 27 Aug 07 @ 8:34 pm
True., Cstoll, but my main focus about this is to be able to rearrange playlists, add to, remove tracks and clean them up all while i am using the current playlist.
geposted Mon 27 Aug 07 @ 9:29 pm
