When will be able to read the changelog of virtual dj 5?
I want to know exactly what new features has, bugs corrected, improvements ...
What controllers does vdj 5 support ?
Thanks in advance
Thanks in advance
geposted Mon 27 Aug 07 @ 11:30 pm
You can read the v4.3 features list.. https://virtualdj.com/products/virtualdj/
And the Update guide for V5.. https://virtualdj.com/support/VDJ5-UserGuide_for_Updates.pdf
Page 2 of the guide gives you a quick list.
As for controllers - No significant controllers were added. However, the MIDI engine was improved and several have report great success with setting up controllers like the VCI-100 and BCD3000 using the MIDI mapper
geposted Tue 28 Aug 07 @ 2:56 am
Thanks cstoll.
any significant improvements ( i refer to internal ones like sound engine, less cpu usage, optimizing some code ...) ?
Any bugs or crashes solved/fixed ?
geposted Tue 28 Aug 07 @ 6:21 am
I want to know whats improvements have made from vdj 4.3 and what bugs are fixed.
Thanks
Thanks
geposted Tue 28 Aug 07 @ 6:10 pm
