Quand je mix mes curseurs font des sons ex: quand je bouge les basses, les hautes, et même mon curseurs de mix. quand j'écoute mon mix ca fait pas très très jolie comment faire pour illiminé ce bug.
geposted Tue 28 Aug 07 @ 3:45 am
Here are the French forums:
https://virtualdj.com/forums/29/French_Forum.html
Good luck! =)
Good luck! =)
geposted Tue 28 Aug 07 @ 3:47 am
Thanks you can answer me in English too if you want
geposted Tue 28 Aug 07 @ 3:57 am
so your getting odd noises in your mixing,
what is your system specification? what version do you use?
geposted Tue 28 Aug 07 @ 9:38 am
It can be a performance issue, try lowering Performance tab in VDJ settings.
geposted Tue 28 Aug 07 @ 4:06 pm
Just disable the option "safe mode" to my mind
geposted Tue 28 Aug 07 @ 10:44 pm
Verion 4.1
geposted Tue 28 Aug 07 @ 11:04 pm
please try the latest demo , you will find its so much better
and try ticking safe mode on performance options like cel suggested
geposted Wed 29 Aug 07 @ 12:04 am
The option safe mode works thank you for the tips
geposted Wed 29 Aug 07 @ 6:35 pm
