Forum: Old versions
Topic: USB Sound Blaster
Hi 2 all..
I have an interesting situation then I'm using my external Sound Blaster Creative MP3+ ..
When I'm trying to record my mix with 2 soundcards, during the recording the sound goes perfect.. But when I open the recorded file, I hear some "skipping" that weren't there before in the original mp3 file..
Does someone have any idea why is that and how I can avoid this problem? (it's not comfortable to use only 1 sound card during the mix..)
P.S. That doesn't happens then i use only internal sound card..
My system is: Laptop Fujitsu Siemens, P-IV 2.4, 512 Mb Ram, 64 Mb video, 40 GB Hard Drive, Vinil ac'97 Audio (internal sound card)
Best Regards to all..
geposted Tue 19 Oct 04 @ 12:22 am
I have the exact same cards as you and have not experienced this issue. Did you update your drivers or just use the driver that windows loaded ? I loaded no drivers just used the ones windows selected.
I installed the Sound Card with the setup disk that was given to me during the buying..
Tell me, Homeboy, in what format you recording your mix?
Tiger, what program are you using to record your mix with? as sometimes the load on the CPU can cause skipping.. I had this before, truly ruins a great mix..
Try using the MediaSource Recorder/Player thing, uses hardly any CPU time
I'm using the VDJ record option..
I'm using the same soundcard as secondary but i didn't install the driver. I recorded some mixes while no other programs running and they sound fine.
