In previous version all the info (IE; skins effects etc) were in programs/vdj.
With ver 5 all that info is in documents. So question is do we delete all the stuff
under programs/vdj or just leave them? Not sure if it would effects v 5.
geposted Thu 30 Aug 07 @ 12:25 am
They used only from v.4 (if exist)
geposted Thu 30 Aug 07 @ 12:39 am
Yep they are in both Program files/VDJ
and Documents/VDJ
So inot good idea to delete the ones in prgm files
geposted Thu 30 Aug 07 @ 12:49 am
If you are no longer using 4.3 as a backup - you can delete the folders (Skins, Plugins, etc) in the Program Files\VirtualDJ -- Do NOT delete the items (virtualdj.exe, ripDVD.exe, etc) in the VirtualDJ folder level.
geposted Thu 30 Aug 07 @ 12:58 am
