tring to set up 2 numark turn tables with external mixer and hercules mk2 sound card but when i go to config timecode it says asio sound driver error
geposted Thu 30 Aug 07 @ 2:44 am
Well i have this too sometimes (M-Audio Conectiv), then i need to switch to any other driver as ASIO into VDJ, press ok and after that back to the ASIO & voìla !
Or you can try to go with "Asio4All" - http://www.asio4all.com
geposted Thu 30 Aug 07 @ 4:57 am
If you're using the Mk2 as your timecode soundcard and not using asio4all as your driver, select the Hercules Mk2 as the soundcard rather than asio. VirtualDJ will then be able to set the soundcard into asio mode automatically. However, should you with you have lower latencies and in general a bit better stability, check out skyfxl's blog about asio4all and the mk2.
geposted Thu 30 Aug 07 @ 5:10 am
