I am using the 16 band EQ plugin to knock down frequencies below 40Hz because they cause my sub to 'POP'. The plugin seems to work well, but it resets the curve after every song. Is there a way to keep it from resetting to flat?
geposted Thu 30 Aug 07 @ 5:34 pm
You can try DJ CEL's Registry tool: http://www.virtualdj.com/addons/tools.html
And disable the option for reseting effects on load. I think it's name is ClearEffectsOnLoad.
geposted Sat 01 Sep 07 @ 11:34 pm
Will do, thank you.
geposted Sun 02 Sep 07 @ 5:30 pm
Tried it, it seems to work. Thanks for the tip!
geposted Sun 02 Sep 07 @ 7:40 pm
