any controller works with vista?
I have bcd2000 sucks/hercues1 great with xp but not vista .
try external mixer that doesnt work with vista either.
before i remove vista and put xp on any information,thats seems to be the answer for vista remove it and headache gone........
geposted Fri 31 Aug 07 @ 2:46 am
http://www.microsoft.com/windows/products/windowsvista/buyorupgrade/upgradeadvisor.mspx
this will tell you what hardware works with vista
the herc will work witht the vista drivers
and the bcd2000 drivers should be ok in vista ,
geposted Fri 31 Aug 07 @ 10:05 am
Not the Herc 1 on Vista
geposted Fri 31 Aug 07 @ 12:42 pm
Right clik on the driver setup , in properties select to run under windows vista :)
geposted Fri 31 Aug 07 @ 7:54 pm
