Topic: Timecoded CD with External Sound Card ASIO
Hi,
Is it possible to use SB Audigy 2 NX (external sound card) with dual CD palyers through the ASIO sound card configuration.
When I try, in the config panel for sound card, I see ASIO Soundblaster USB Audio but when I click on the ASIO config, there is nothing happening. No configuration panel. Would Audigy 2 NX not ASIO compatible?
Is there a way around this?
Thanks
geposted Tue 19 Oct 04 @ 11:50 pm
Yes and no..
the short is that the Audigy 2 NX does not support asio from Creative's side of things, however..
www.usbasio.com does offer some ASIO drivers for use with certain cards, so i'd give their demo a try first..
The ASIO panels should be blank, unless you have some 3rd party drivers installed.
sorry previous post was wrong:
url:
www.usb-audio.com
