Hey,
I have a question ...
When VDJ analyzes a song, it marks the beats and the "main" beat is marked with a wider indicator than the minor ones ...
so, in some of my songs VDJ gets the beats right, but misses the "main" beat by one or two.
Is there a way of shifting the marks to left or right?
geposted Fri 31 Aug 07 @ 2:15 pm
U mean the CBG??
U could edit them in the BPM settings or u could take alook at DJ in Norway blog for that:))
geposted Fri 31 Aug 07 @ 2:38 pm
what is a/the CBG?
Where do I find DJ in Norways Blog?
geposted Fri 31 Aug 07 @ 2:44 pm
You can use shortcuts. For Example: Use Ctrl + G to shift the markers to the left (adjust_CBG (4), value = -1) and use Ctrl + H to shift the markers to the right (adjust_CBG (4), value = +1). You will be able to create these shortcuts by going to Config/Keyboard shortcuts/Add/Rythm/adjust_CBG(4).
geposted Fri 31 Aug 07 @ 2:47 pm
https://virtualdj.com/blog/dj-in-norway/
U must thanks DJ in Norway for this info;) n dj Nyiko is right too..
CBG is the terms for that boxes u were saying:)
geposted Fri 31 Aug 07 @ 2:48 pm
allright, I will try it out !!!
Thanx so far.
BTW: Great forum !!! Great people !!!
Thanx so far.
geposted Fri 31 Aug 07 @ 3:00 pm
exactly what I was looking for, THANK YOU
geposted Fri 31 Aug 07 @ 3:46 pm
