Topic: Loading a playlist
Ok i have read the on-line help but im stumped, how do i load a saved playlist? i just can't find a way.
Thanks in advance.
geposted Wed 20 Oct 04 @ 1:08 pm
you just go through the same browser that you find your music files and you can either drag and drop them from into the playlist or you can see their contence in the main browser like another folder. i also think dbl clicking on them has a function but cant remember what it is exactly
Save your playlists at the "playlist" folder within
vdj forder. Then just browse this folder like a normal folder.
You can also organize your playlists in subfolders if you wish..
Easy ?
