hey all...
like i figured out bout the itunes library being the cause of the database woes that i was having which was also later confirmed by cstoll, basically if the itunes library is out of whack and all over the place, the vdj search will also spew out some random results....
if you're like me and don't really use itunes, but have it all the same, do what i did...i just deleted the whole itunes library...ill manually add to my pod later on thru explorer..
however, if itunes is an essential part of your life and the library is not in tip top condition, check out this great freeware app i found, that will fix your library, no muss no fuss.....
http://www.softpedia.com/progDownload/iTunes-Library-Updater-Download-24581.html
cheers
DJ Rudra
cheers
DJ Rudra
geposted Sat 01 Sep 07 @ 6:58 am
Explanation found here as well -
VirtualDJ 5 - Database Issues - Explanations and further discussions
geposted Sat 01 Sep 07 @ 8:36 am
