Is there a way to print the database in ver 5?
Previously there was database text, and you could print a list of your database if so desired.
I tried to open the XML in word but it is not the same.
geposted Sun 02 Sep 07 @ 12:15 am
i really wish they would do this ......don't tell us the workarounds , just build it in .......it would be great to print the virtual folders especially
i have a little print utility called PrintKey that makes the old printscreen a one stroke operation again .... anything on the screen can be printed
geposted Sun 02 Sep 07 @ 12:59 am
