I don't want to see my pitch moving with TCV . do somebody knows the values in config ??
geposted Sun 02 Sep 07 @ 3:48 am
If you up your "Pitch Sensitivity" to 2000, it will be back at what it was set in older versions, and your pitch shouldn't move around.
geposted Sun 02 Sep 07 @ 4:03 am
thanks
geposted Sun 02 Sep 07 @ 4:46 am
I've tried 2000 and other values ..but my pitch is still moving -
geposted Sun 02 Sep 07 @ 7:26 am
yes, i also encounter these problems.. any ideas? The previous version did not jumpin....Or is it my TVC issue still exist as last time, i using stanton final scratch TCV Btw,:(.. Grounded to mixer.
geposted Sun 02 Sep 07 @ 2:21 pm
this problem has been reported by others , deav team is working on it -
geposted Sun 02 Sep 07 @ 3:39 pm
You don't want to see the pitch moving, are you talking about just the slider? What about the bpm value on the screen, do you want that to move?
geposted Sun 02 Sep 07 @ 3:44 pm
Try 2000ms pitch sensitivity, and turn off clear sound as well....
Does that help ?
Does that help ?
geposted Sun 02 Sep 07 @ 4:06 pm
no , with other values is the same :-(
geposted Sun 02 Sep 07 @ 4:41 pm
i have the same problem! hercules mk2 as soundcard and 2 stanton t.120c turntables. they do not need to be grounded. if i move the pitch to 2000ms its not jumping but it is also not possible to sync the pitch to for example 128.5bpm. it mostly goes to 128.6 or or 128.4bpm. clear sound is deactivated. pitch is not juming if i go down to 1200ms and clear sound is deactivated.
greetz
greetz
geposted Mon 03 Sep 07 @ 12:40 am
ok i 2 have this problem please try setting tcv to 45 rpm on computer and turntable works 97% for me still jumps back and forword 0.1% every now and again hope this helps someone else
geposted Mon 03 Sep 07 @ 1:41 am
This is a very, very interesting problem...i have it to...i hope this issue is being resolved as we speak, if not i will still continue to use my DAC-3 for better mixing.
geposted Tue 04 Sep 07 @ 9:39 pm
as already stated, being fixed in future by dev team.
try 2000ms like others have suggested
geposted Wed 05 Sep 07 @ 7:46 pm
Well even if you use 3000ms won't help the problem. Did you ever tried to start both TTC's on the same time and listen to the same songs playing with the crossfader on the middle... what i get is flanger effect witch is normal, but not stable, it goes little bit back and forward on the same time with the pitch slider on the screen.
geposted Thu 06 Sep 07 @ 6:25 am
