Sometimes, the programm hangs when I do a search. A window is showing up with "sorting".
Is it possible to search withing this screen is coming up?
geposted Mon 03 Sep 07 @ 10:54 am
Read Here - information about optimizing your DB to get better performance out of the new database architecture.
geposted Mon 03 Sep 07 @ 6:12 pm
Thanks m8.
Did all the things.
Next weekend we will see.
Did all the things.
geposted Mon 03 Sep 07 @ 9:24 pm
Why wait until next week. Did you see an improvement after doing the recommended steps?
geposted Tue 04 Sep 07 @ 3:03 am
why tempt the fates during a gig ??? check now
geposted Tue 04 Sep 07 @ 7:46 pm
It looks ok.
I don't use the covers, so I set everything on the browser tab to No.
Then I recursed every root folder.
Do I need more things to do if I don't want to have a freeze (sorting) when I'm searching for a song?
geposted Tue 04 Sep 07 @ 8:43 pm
My text from the like I provided --
Yes the first couple times trying to sort or even retrieve the entire database can be interesting. Again recommend that you do this in chunks, it makes a difference in the long run. Recurse your folders like you did for the importing process - then click on the Artist column let it sort, then the Title column again let it sort. Do this for each folder chunk. When you have covered your whole collection. The type an asterisk * in the Search box and click on the Artist column - LET IT Work. Once done - click on the Title column - LET IT Work.
If you have done this... then things should go well.
geposted Tue 04 Sep 07 @ 8:57 pm
Thanks m8 !!!
I did all that.
Tested it ( for an half hour just searched for some tiltles) and it didn't freeze at all.
Hopefully it stays like this.
To everybody who helped me: thanks a lott
I did all that.
geposted Tue 04 Sep 07 @ 11:09 pm
Awesome. Glad I could help.
geposted Wed 05 Sep 07 @ 12:00 am
