hi obviously im new to this.. Im looking for a bpm software.. I know vdj, at times, has the wrong bpm. is there a way I can manually count the BPM? if so how? or should I just look for a bpm counter software
geposted Wed 05 Sep 07 @ 1:48 am
right click the track select bpm then manual edit
or load that track and then right click the same file in the browser then select bpm manual edit and
more options will show loaded then not loaded on a deck
on version vdj pro 5.0 R2
hope this helps
hope this helps
geposted Wed 05 Sep 07 @ 1:55 am
Page 29 - of the manual - if you have installed v5.0Rev2 it's in your My Documents->VirtualDJ folder.
geposted Wed 05 Sep 07 @ 4:56 am
I think this is what you're looking for:
http://www.mixmeister.com/download_freestuff.html
OO
OO
geposted Wed 05 Sep 07 @ 6:17 am
thanks double 0
geposted Wed 05 Sep 07 @ 7:41 am
You're welcome.
Here's a thread that you should read before using it:
https://virtualdj.com/forums/57449/General_Discussion/MixMeister_BPM_Analyzer.html?highlight=MixMeister%20BPM%20Analyzer
OO
OO
geposted Wed 05 Sep 07 @ 11:38 am
