I have a couple ripped videos that will play on the laptop s dvd player but will not play in virtual DJ. I see the video bit get a loud hiss with the audio. How can i fix this?
geposted Wed 05 Sep 07 @ 4:04 am
what format are they? .vob
vdj is not causing a hiss mane
geposted Wed 05 Sep 07 @ 4:09 am
I know that VDJ is not causing the hiss. It must be a protection on the dvd. They are VOB files.
geposted Wed 05 Sep 07 @ 6:37 am
Open the file in PowerDVD oir similar, then click to hear the other audio streams, you may find you need to re rip it and select a different audio stream
geposted Wed 05 Sep 07 @ 12:58 pm
Hello,
I ripped karaoke dvd´s.
Just used the imtoo dvdripper.
It´s easy, a piece of cake.
No sound problems at all.
geposted Wed 05 Sep 07 @ 1:03 pm
