Hi VDJ Staff,
Right now I already posted some questions on another forum about the next (new?) feature's and wait for answers:
(This could be a description how to set the new features:)
- New Lock-function:
Give deck A and deck B at any point both a cue-point and then lock or sync both decks (NOT like the lock or sync for BPM!) so that they response exactly the same while using just 1 of the decks to jog backward or forward. While locked they will also start both at the same time by using just 1 Play-button.
- New Go-To-function:
Give deck A and deck B at any point both a cue-point. Then give just 1 deck (either Deck A or B) at another point a second cue-point. If now the New Go-To-function is used the deck WITHOUT second cue-point will automaticly go to the second cue-point which is set for the other deck.
For both functions the interface should contain some new extra buttons and displays, as everything should be within reach and view.
Actually those functions are just an basic analog editing tool but can be used for so much more. Integrating it in Virtual DJ gives users an extra mixing tool and can save time. It just would make things even easier.
As they say: the only limit is your own creativity!
Regards,
Renato
(I apologize for the fact that this subject now is on more then on forum.)
Regards,
Renato
geposted Wed 05 Sep 07 @ 5:56 am
PS Important additional Note for the "New Go-To-function":
NOTE: With this type of GO-TO feature the TIME-FRAME between 2 cue-points of a deck are used to automaticly find the second cue-point for a deck with just 1 cue-point to set the same time-frame for both decks.
geposted Sat 08 Sep 07 @ 8:56 am
@ikbenliebrand - you were asked not to make multiple posts. Yet, you still posted this here. I know you are excited about you idea but please do not flood the forums. Post it once and only once. This thread is closed and discussion will continue in the General Discussion thread.
http://www.virtualdj.com/forums/76315/General_Discussion/Locking_deck_A___B.html
geposted Sat 08 Sep 07 @ 4:01 pm
