Hi,
Minor bug, but annoying none the less!
VDJ does not save the "Disengage beatlock" setting.
Each time I load VDG, it resets to "manual" no matter what I set it at the last time.
I'm using 2.04
I'm using 2.04
geposted Fri 22 Oct 04 @ 3:24 am
Thanks, it's been corrected.
geposted Fri 22 Oct 04 @ 12:20 pm
And while on the beatlock topic... is this a bug? :
When you have "disengage beatlock" set to "on load" it only disables it for the deck you load a song on, not for the other deck too.
For this feature to be useful it should disengage beatlock on both decks, since there is no point of having the playing song still beatlocked. What happens is that when you start cuing song 2, the playing song will try to adapt to it by changing pitch and realigning itself with the beats, making for a really bad sounding experience!
So can we have the option to "disengage both beatlocks on load" ?
geposted Fri 22 Oct 04 @ 6:19 pm
I don't think it's a bug, as both Beatlocks act separately since VirtualDJ 2.0...
macourteau
macourteau
geposted Fri 22 Oct 04 @ 8:42 pm
Ok it now disengages on both decks
geposted Sat 23 Oct 04 @ 12:52 pm
You guys get my vote for Best Dev Team Ever!
geposted Sat 23 Oct 04 @ 11:08 pm
