Can you use the registry tool for VDJ 5 ?
What are the usefull registry settings to change/edit.
For example: Is it usefull to use the speedload in de registry tool?
geposted Wed 05 Sep 07 @ 4:22 pm
Yes download the v1.6.1 registry tool - it has access to additional registry settings for v5. Covered in the manual and updates guide.
geposted Wed 05 Sep 07 @ 4:47 pm
Thanks, but can only find v1.6.2 and no manual.
Can you tell me please where to found both?
geposted Wed 05 Sep 07 @ 5:22 pm
Here is the link
https://virtualdj.com/addons/view.html?type=tool
geposted Wed 05 Sep 07 @ 5:57 pm
Sorry, thought it was still 1.6.1 -- bogart's link is good.
geposted Wed 05 Sep 07 @ 7:04 pm
Cstoll and Bogart,
Thanks for your help, I also cound find oly 1.62 but I can't find any manual.
geposted Wed 05 Sep 07 @ 8:11 pm
The manual may be in the zipped file. Did you unzip it yet? The latest version, may be the only one available.
geposted Wed 05 Sep 07 @ 8:24 pm
Sorry, I can only download an .exe file.
So no zip at all and no manual.
geposted Wed 05 Sep 07 @ 8:38 pm
There is no manual for the tool. The entries are pretty self explanatory. However there are a couple that are covered in the last page or so of the Updates guide I wrote for V5 -- https://virtualdj.com/support/VDJ5-UserGuide_for_Updates.pdf
geposted Wed 05 Sep 07 @ 8:45 pm
Cstoll,
Thanks again.
Now it's more clear to me.
Gonna give it a try.
Thanks again.
geposted Wed 05 Sep 07 @ 9:49 pm
