I'd like to see the file list in vdj show up like this, I know we can change it to show artist first, but I'd like the bpm first because I consider it more important
geposted Fri 22 Oct 04 @ 7:40 am
you should be able to do that by editing the parser pretty easily
geposted Fri 22 Oct 04 @ 10:26 am
H-O-W?
geposted Fri 22 Oct 04 @ 1:38 pm
I don't think modifying the parser would change anything, because what you could do is to show the BPM in the title column, but that column would remain called "title", and you wouldn't be able to put a title or an artist in the column BPM...
macourteau
macourteau
geposted Fri 22 Oct 04 @ 3:57 pm
Cyderhouse> you know you can change the default sort order so that it's by BPM right?
doesn't really address your issue but at least lets you put the emphasis on BPM.
in registry, under HKEY_LOCAL_MACHINE\SOFTWARE\VirtualDJ, change AutoSort to "3"
Nicolas
Nicolas
geposted Fri 22 Oct 04 @ 6:06 pm
I think what is simply needed here is the ability to drag and drop the column headings of file browser so people can arrange them in whichever order they want. Most MP3 player support that featurer as well as all file views on Windows.
geposted Fri 29 Oct 04 @ 11:50 pm
