Forum: Old versions
Topic: Problems when frequency crossfading...
Hi team
Had a good 2 hrs on VDJ last night on a dry run, I want to be sure things are all ok before changing over from Atomix when working live..
One thing that seemed to happen quite often is:-
Situation:
deck a looping 4 beat, deck b running from cue.. main crossfeeder central....
When i use the mouse to adjust either decks frequency crossfaders, i occasionally get a 'skip' or one of the decks seems to hesitate slighty....
this happened probably 3 or 4 times each hour..
Occassionally the 'kill' buttons also caused a similar problem.
I couldnt seem to intentionally replicate the problem though..No real pattern of events etc...
Any thoughts
I am using the Darkfun Skin
Set up is:-
AMD 2.0ghz , 1024mb Ram
Internal audigy/external extigy
Windows 2000 Pro
Thanks guys
Stu
P.S. love the new adjustable loop facility !!! superb
geposted Fri 11 Jul 03 @ 10:36 am
Could be a problem between extigy and ur proccessor
It didn t work at all on my pc (permanent beat skiping with atomix)
I don t think this is the main reason but u can check in case
Thomas M
No problems with Atomix
Use it live at least twice a week with same set-up...
Stu
yes i have this exact problem!!
my post about it is in the tech suppor forum
