Maybe someone asked this question already but I couldn't finde anything about it. yesterday I tried to start organizing my music with the virtual folders like Oldies, Dance, House etc. There were two things, maybe bugs, I don't like.
1) Why can't you change the folder input after you add music. can't delete music. I would be better if the folders could delete or change its music automatic by comparing the global database
2) After adding music to the folders, in my database I found several duplicates, not physicaly just in the database
Can someone tell how to handle with virtual folders as best?
Thanx,
Daniel
Thanx,
Daniel
geposted Thu 06 Sep 07 @ 10:04 am
Check out the filter folders in version 5, sounds like the answer to this question, you can setup things like Top 20, Certain genres etc.
https://virtualdj.com/forums/76187/General_Discussion/VirtualDJ_v5_-_User_Guide_-_Full_Guide.html?highlight=user%20update
Check that link for the PDF manual, which explains the filter folders in more depth.
geposted Thu 06 Sep 07 @ 12:33 pm
Why not use the Genre field for that and use the built in Genre sort for what you are doing.
To remove a file from a Virtual Folder - Right-click and choose delete -- if you are doing it from a Virtual Folder it only removes it from the Virtual Folder
And for #2 explain how you found duplicates ? Did you do a search while still in the Virtual Folder ? If yes, then yes you will see 2 entries - 1 for the reference in the Virtual Folder and 1 for it's true location.
geposted Thu 06 Sep 07 @ 12:34 pm
