Hello, I have a question about mixing videos in VDJ 5 with Numark iCDX. If I pres the left parameter knob while playing videos it makes an auto videomix, but if I turn the knob it´s mixing the audio as much as I turn it.
Now to my question or query... Couldn´t it mix the video instead, so I can deside how much and how long I want the mix to be.
Hope for an answer.
Regards // Dj Nicevalley
Hope for an answer.
geposted Thu 06 Sep 07 @ 11:58 pm
Are you using an external mixer ? If so, go to Config->Options tab and for the Crossfader option set it to Disabled. Now try...
geposted Fri 07 Sep 07 @ 12:19 am
Yes I am, I will try it tomorrow... hope it will work :)
Thanx :)
Thanx :)
geposted Fri 07 Sep 07 @ 12:29 am
It works awesome! Got an iCDX myself and have used it. Plus now you can move the software crossfader anytime and it doesn't effect the audio.
You will like it!
You will like it!
geposted Fri 07 Sep 07 @ 12:50 am
