Can I suggest that for 5.1, we are able to take cd covers directly off a webpage straight into the song info box.
I don't like the way that you are restricted into choosing from the ID3 tag, and the three search engines.
Cheers,
Rob
Cheers,
Rob
geposted Fri 07 Sep 07 @ 12:36 pm
I agree. Also we should be able th choose a jpeg on a local drive as well. Andy why is the resolution on the cover so low (compared to itunes)?
geposted Fri 07 Sep 07 @ 12:55 pm
Cover files for every song are stored as hidden jpg files (same filename, same directory)
So for every xxx - yyy.mp3 song with cover there is a hidden xxx - yyy.jpg in the same folder.
If you have a better cover just copy/rename it this way to replace the downloaded one.
geposted Fri 07 Sep 07 @ 8:20 pm
