Is this possible?
geposted Fri 07 Sep 07 @ 5:28 pm
Please use the search in the forums.
Yes, Serato TCV can be used. For now it doesn't support needle drop.
However, once the SSL timecode plug-in releases you will be able to use the vinyl just like using the VirtualDJ vinyl.
geposted Fri 07 Sep 07 @ 5:46 pm
ok, I did search for this and I saw that some people said the pitch is off by around 6%. I was just wondering if this still happened or if the only problem now was the needle drop. Thanks.
geposted Fri 07 Sep 07 @ 7:02 pm
