Forum: VirtualDJ Skins
Topic: FLOOP DJ(1280x800) - Page: 2
1024X768, I just posted under this topic cause I thought the person made both versions and can help me. Thanks Brian
Workin on it.
Thanks. Brian
Funny thing is that this skin 1024X768 works on my other machine without external video enabled, I don't know if that will help you or if you know of a bug. Thanks Cheers Brian
can someone PLEASE tell me how to resize the beat scrolling window. i shrunk it and i have no idea how to get it back. thanks!
did you edit the XML or did you just change the size the zoom size when using the skin?? If you didnt touch anything in the XML then all you should have to do is click on the waves with your mouse and scroll the wheel.
