Forum: VirtualDJ Skins
Topic: FLOOP DJ(1280x800) - Page: 1
Wide screen skin has just been posted. Please feel free to drop comments here.
geposted Sat 23 Oct 04 @ 1:08 am
Can you make it a 1024X760???
Very nice skin DJ Manixx!!
Im anxious to try it out but i seem to have problems activating it on VDJ. Is there something that I am missing when installing this skin? The error message im getting is "invalid skin file". Ive saved it to skins folder but unfotunately its not working. I would really appreciate anyones input.
Great work!!
How do you get the auto scratch to work ?
1) Launch VDJ and go to the setup.
2) Go to the lugins section and select what kind of autoscratch you want to test.
3) Select a skin with the autoscratch button or create a shortcut for it.
4) Activate autoscratch and ... scratch.
Ditto!!! Thanks Clax.
My problem with the (1280 x 800) is that I cant scratch with channel 2? do you think that its actualle my software? I dont 'cause the other skins scratch normally. Any ideas?
I noticed there is an update of the Floop skin to V3.1
I am using the skin which is perfect for a long time, however in 1280 x 800.
Are you going to post this version also??
many thanks,
freek
I'm working on updating all other screen resolutions.
Thanks in advance.
I'm just thinking it would be better to have the level sliders close to the middle (less mouse movments).
Sure Clax
can someone tell me where i can download this skin. i can only find the version with the smaller resolution. thanks!
never mind, i found it.
Where did all the Floop skins go?
They are no longer on the skin page.
I tried to update the skin to v3.4 and poof everthing is gone.
rember me please
He Marnix,
I am still using the Floop 1289x800 without video mixing etc.
I hope you can help me how to edit it it.
What i want to modify/add is just in BPM field, the star if the bpm analyses has typed the number as a good for auto mixing.
In this way i know when i can do half automix. I only turn down bass and treble during fading.
Or i will mix total manually. Set fade in the middle and level down the playing number and start the new number.
freek
Anyone using the Floop skin with video. I am having problems with the video in the center of it jumping with white lines in it. I wanna use that skin but it isn't working for me. I tried re-downloading it and it still didn't work correctly. Brian
Which resolution version are U using?
77%
