Why does the skin creation guide say the adjust_cbg (etc) controls are obsolete?
In the skins I've found that have CBG controls I've found them very useful, much more accessible than fiddling around with the pop-up edit_BPM window!
Is there some esoteric reason for this or just the taste of the developers?
Cheers
b
Cheers
b
geposted Sat 23 Oct 04 @ 10:56 am
fortunately they say they're obsolete but they keave them in there!
I use them all the time, I also mapped my XP10 shift1+ to adjust_cbg and shift2+ to adjust_cbg4
geposted Sat 23 Oct 04 @ 12:27 pm
I often adjust CBG's too while playing.
For a fex songs that's very useful; especially those with different phases.
geposted Sat 23 Oct 04 @ 6:27 pm
So I can assume it's just developer taste? OK...
Something else I need to understand is how to better beatmatch tunes - VDJ often gets the bpm as a multiple of what it actually is, any easy way to correct that?...
Can I add buttons for X1/2, X2 etc?
Cheers
b
Cheers
b
geposted Sat 23 Oct 04 @ 9:37 pm
