Hello again!
Does anyone knows if its possible to change the sensitive of the jogwheel pitchbend on the iCDX when using VDJ 5.0.
Or is it anyone who can make a plugin for it?
// Richard
// Richard
geposted Thu 13 Sep 07 @ 7:05 am
Not sure if icdx supports midi but if so you can change values in midi mapper.
geposted Thu 13 Sep 07 @ 6:27 pm
By sensitivity are you talking about the amount of pressure needed or are you talking about the amount of bend in relation to the platter movement?
If it is the latter, what I did was change the "disc" speed under options to "45" instead of the "33" I had it on and it made it much more manageable.
Maybe this will help.
geposted Thu 13 Sep 07 @ 9:06 pm
Us the function:
set_scratchlatency()
geposted Thu 13 Sep 07 @ 9:26 pm
Thanx alot.. I will try it out and see if it works.
Any suggestion of value in latency settings? Or do I have to try it out?
// Richard
// Richard
geposted Thu 13 Sep 07 @ 10:22 pm
