Some of my Mp3 songs from my external Hard drive are loaded with no gain. OR negative gain so there is NO sound. I have to turn the gain up on these MP3. I don t like to be surprised and have no sound when I fade over. How can these songs be fixed to have gain when they are loaded to be played? All of my songs have been scanned with the MP3 gain program and BPM anaylyzer.
Thanks.
Thanks.
geposted Sat 15 Sep 07 @ 5:17 pm
If this is in ver 5 I also have had many like that.
What I found is if you highlight the song and then fo to file info: check the BPM.
If it the BPM is there except it is not in the BPM box; but rather under it. Just click the arrow and it will put
it in the BPM box. If however there is no BPM shown you need to re analyse
All should be good.
All should be good.
geposted Sat 15 Sep 07 @ 8:13 pm
Thanks I will try it.
geposted Sun 16 Sep 07 @ 6:47 pm
Happened to me, also.
geposted Mon 17 Sep 07 @ 12:25 am
