Hi there!
Why can´t I scratch when I use "4.1> External Mixer Mode"
It works in "Normal Mode"
I Use Soundblaster "Audigy" with the latest updates..
Thankfull for Answer/Fredrik
geposted Mon 25 Oct 04 @ 5:09 pm
"4.1> External Mixer Mode" and others audio settings are only available in the full version, and not in the demo version.
geposted Tue 26 Oct 04 @ 7:42 am
Strange?
Because I have the same problem with my Atomix Program?
And I am a Reg. Full User with that program?
geposted Thu 28 Oct 04 @ 6:52 pm
well, its easy to know if you are a full user or not:
- If you bought the program, legaly, you are a full user.
If not, you are a demo user, and the demo have some limitations compared to the full version
geposted Fri 29 Oct 04 @ 12:17 pm
Frederik F: Please enter your serial number in your profile (AtomixMP3 or VirtualDJ).
geposted Fri 29 Oct 04 @ 3:01 pm
I Have tryed to write my serial (Atomix) but it wont work on this forum,only at Atomix site??
geposted Fri 29 Oct 04 @ 8:19 pm
there is a different licence for the two different programs....
Atomixmp3 and VirtualDJ is not the same program, and does not have the same licence...
so, guess you have the demo for VDJ, and there are limitations in the demo version
geposted Mon 01 Nov 04 @ 1:31 pm
YEAH Norway!...
I know that...but it´s the same Bug in my Atomix Program,and I´m a Licenced User with Atomix Program....
Maby I should write on Atomix forum instead.
Why do you need my Serialnumber here?
geposted Wed 03 Nov 04 @ 6:13 pm
