I'm finding graphics cards model numbers quite confusing.
What can anyone tell me about this card:
512MB NVIDIA GEFORCE GO 7950 GTX GRAPHICS CARD (laptop)
Gary
Gary
geposted Mon 17 Sep 07 @ 5:40 pm
NVIDIA GeForce Go 7950 GTX
The NVIDIA GeForce Go 7950 GTX is top of the mobile graphic cards line from NVIDIA (of the 7000 series) and predecessor of the 7900 GTX graphics card. It enables the user to play all current (10/2006) games fluently in the highest resolutions and options. As a consequence, the heat is correspondingly high. Therefore it can be used only in DTR laptops (17"). At moment, there is nothing better for gamers (except the SLI version with 2 cards).
The performance can be compared partially even with the Desktop 7950 GT video cards (partially a bit better, according NVIDIA). Therefore, the Geforce Go 7950 GTX is able to display actual games like F.E.A.R., Company of Heroes, or Call of Duty 2 fluently in high details and high resolutions.
Manufacturer NVIDIA
Series GeForce Go 7000
Codename G71M
Pipelines 24 / 8 Pixel- / Vertexshader
Core Speed 575 MHz
Memory Speed 700 MHz
Memory Bus Width 256 Bit
Memory Type GDDR3
Max. Amount of Memory 512 MB
Shared Memory no
DirectX DirectX 9c, Shader 3.0
Current Consumption 45 Watt
Transistors 278 Million
Features HDR, Intellisample 4.0, UltraShadow II, PureVideo, CineFX 4.0, PowerMizer 6.0, Transparency Antialiasing
Notebook Size large
Date of Announcement 12.10.2006
Information 90nm, 278 Mio transistors, MXM-Module, Drivers are available at nvidia.com
Link to Manufacturer Page http://www.nvidia.com/page/go_7800gtx.html
Text taken from this links
http://www.notebookcheck.net/NVIDIA-GeForce-Go-7950-GTX.2121.0.html
hope this helps:)
Manufacturer NVIDIA
Codename G71M
Core Speed 575 MHz
Memory Type GDDR3
Shared Memory no
Notebook Size large
hope this helps:)
geposted Mon 17 Sep 07 @ 6:43 pm
Yes, that helps :)
Does anyone have any experience of using it with VDJ. Does it work ok?
Gary
Gary
geposted Mon 17 Sep 07 @ 7:10 pm
From the looks of it , i think it might werk well with video in VDJ,, using ddr3, no shared memory n up to 512 gb.. etc. i also wish to koe more of this cards.. so if there is anyone have use it , do share ur experience.thks:)
geposted Mon 17 Sep 07 @ 8:18 pm
