Ok here's my problem guys,
I am using timecode, and I am using a splitter
one goes to the maya 44 the other goes to the phono input on my mixer
that way i can switch from timecode to LP without a problem..
Timecode sounds fine.. but my audio output is lower with the spliter
what do you think?
what do you think?
geposted Tue 18 Sep 07 @ 6:41 am
Yes there is a quality lose that can occur. It all varies depending on the turntable brands.
If you are using v5, the Timecode_bypass option is back and can be used to pass the standard Vinyl through VirtualDJ. Plus you can apply the effects and EQ of VirtualDJ to the output. I would try playing with that option and see if things sound better.
geposted Tue 18 Sep 07 @ 1:34 pm
Is this low of output specific to the turntable or the stylus/needle...
Do you think if I get a higher output needle it will help make up for the splitter??
I am currently using orotophon concord pro needles
maybe the digitracks or nightclubs will produce a better sound.
The reason for not using passthorugh is.... I mainly use the computer
but when I go to Vinyl it's because the computer is frozen.(Tell me about it!) I need to keep it out the loop
as a backup.
as a backup.
geposted Tue 18 Sep 07 @ 6:25 pm
