Bit of a farout question i hav'nt seen anything on it yet, there is probably a reason why? :-/
Will virtual dj ever have a third deck, just for like acapellas and samples so you can keep them loaded and scratch over the top of the other tracks...?
geposted Tue 18 Sep 07 @ 2:12 pm
You can have that with multi instance skins and it was asked for before.
geposted Tue 18 Sep 07 @ 2:17 pm
Sorry in my other question no one answered it, i remembered someone mentioning multi instance skins but was'nt sure what they meant and they didnt specifically acknowledge they were talking about skins for 3 decks,
sory am abit nooby too all this stuff.
geposted Wed 19 Sep 07 @ 10:19 am
you get 4+ decks.
It has issues sometimes if you use external controllers
I didn't experiment much but I am sure you can install cdj twice and reference each instants to
a seperate configuration.
For example:
Herc controls instance 1
time code for instants 2
I was able to change the settings while in VDJ
but, the last instants closed seems to keep the settings.
Any who~
Have fun
DJ SMG,
For example:
Any who~
Have fun
DJ SMG,
geposted Wed 19 Sep 07 @ 3:02 pm
Cannot use the record feature using 4 decks, correct me if I am wrong. Would have to use recording software to record.
geposted Wed 19 Sep 07 @ 3:40 pm
You can use the recording feature.
you need to record from the correct source
you may have to feed it to a line in,
I use external mixer so I can record everything via line in
geposted Wed 19 Sep 07 @ 4:19 pm
