I have recently invested (a lot of money!) in getting a new computer system to run CUE for my Video Sets......
The system was designed after liasing with Numark (minimum requirements etc, etc..) I didn't build the system by the way.....a company made it for me. It's a 4u 19" rack mount system and looks the biz.....
Anyway, I seem to be having a few problems...
1, When you drag an audio or video file into CUE that has not been added to the CUE library it minimises and maximises the screen....if you have video set to window it seems to do weird things....when you play files from the library it is fine???
2, When you try adjusting the pitch of audio/video files once they have been loaded and are playing....it goes glitchy....it's not smooth? That's even if they have been added to the library....
I know you will want to know what system I have, so here is the full spec....
Intel Core 2 Duo E6600 Processor
2GB OCZ DDR2 1066MHz RAM
Two 500GB Western Digital SATA-ll Disks on a RAID-1 Array
Samsung 16x SATA DVD-RW Drive
ESI Maya 44PCI
ATI X1800GTO 256mb with VIVO
It's running on Windows XP.....not Vista.
Please help....I know it must be something to do with the settings but....I wouldn't know where to start.
Thanks in advance
ESI Maya 44PCI
Thanks in advance
geposted Wed 19 Sep 07 @ 12:48 pm
what version of cue are you using?
geposted Wed 19 Sep 07 @ 2:40 pm
Are you dragging files from another window and dropping it into cue??
if yes, I will use the cue browser insted. Add Folders as favorites and
make use of the Search DB, it will save you lots of time.
geposted Wed 19 Sep 07 @ 2:58 pm
Are there any programs running in the background? Try this.... Start...Run... Then type msconfig in the box ... Go to the startup tab and uncheck any program that you don't want to startup when turning on your computer. Also, next to the startup tab will be services, click that then check off hide all microsoft services then check to see if there are any services you can stop from running. After you go through all of these steps you will be asked to restart. Restart your computer then try running the video. Maybe there are some resource hungry program running. You might already know about this, but it's worth a try.
geposted Wed 19 Sep 07 @ 3:53 pm
One other thing I have noticed in your configuration is your video card. Could also be causing problems. It's a little slow compared to today's standards. I understand it has vivo, but there are stand alone video cards you can get.
geposted Wed 19 Sep 07 @ 3:57 pm
What are you talkin about???
There is nothing wrong with that video card it is 256mb dedicated and also gddr3.
geposted Wed 19 Sep 07 @ 11:26 pm
I am still having the same problem....I have downloaded the latest update....version 5.0 rev 4.......
I have tried turning some of the things off (on start up) but nothing seems to have happend....?
Any suggestions?
Any suggestions?
geposted Thu 11 Oct 07 @ 2:02 am
You mention pitch as well..
Do you control the software by timecode by any chance?
And , your system has ROCKING specs, so should run videos like a baby.. But, could there be an IRQ conflict between your graphic card and some other intense hardware?
geposted Thu 11 Oct 07 @ 2:30 am
hi all....thanks for all your help and advice....that particular problem has been solved.....
I'm not using time coded vinyl........it was.....wait for it....
....the setting on the sound card.....i was trying a few things to get a headphone output and voila...seems to have done the trick....pitch and crossfader are now smooooth.....no glitchyness at all.........
I still do have a problem with the main screen minimising and freezing at times.....It seems to happen a lot when the output is set to window....I'm not sure what an IQR conflict is and what to do to solve it?
geposted Fri 12 Oct 07 @ 1:59 pm
the video out put should go to your monitor or projector , in the drop down does it list your video card ?
geposted Fri 12 Oct 07 @ 3:31 pm
