heyy hi 2 everybody..:) well im a hondurean Dj.. well i just wanted 2 know.. how can i use the broadcast so my friends can listen to my mixes? online but using with my own computer !please answer thanx
geposted Sun 23 Sep 07 @ 6:25 am
you need to run a shoutcast server. if u run it on your computer you are going to be limited to the number of people that listen because of your bandwith. depending on how many people u want to listen to u will depend on how much bandwith u will need. if its over 2 people @ 96kmp3 I would recommend using a external server. I personally could set u up with a shoutcast server for .55 cents a listeners @ 128k....its available in 10 listeners increments. Minimum is 10.....included is the technical assistance to get it up & running. This will be a solid server with plenty of bandwith to meet your needs.
man i sounded like a salesman.
btw u don't need an external server....but remember you will only get like 2-3 listeners by using your computer as the server. hope that helps
geposted Sun 23 Sep 07 @ 9:11 am
https://virtualdj.com/forums/59741/General_Discussion/The_Ultimate_Guide_to_Broadcasting_With_Virtual_Dj_).html
the number of people who can connect to vdj as a server is dependant on ur ram and internet speed a faster pc and faster broadband can have more connections
geposted Sun 23 Sep 07 @ 12:13 pm
